Bobster691
Hi all!
Having some troubles connecting my Sony TV to Onkyo Amp.
Connecting through HDMI ARC from the TV to the Amp. Checked all 3 different HDMI ports, and I dont hear anything coming through the speakers at all, but the Amp is recognising the input from the TV, as the TV changes the speaker source from internal to Audio System and the Amp, if on standby, powers on when I turn the TV on, so it looks like the amp is receiving signal from the TV? If I turn the TV volume up, the Amp volume goes up too....(but no sound output)
I've tried changing the input modes on the Amp for HDMI 1 (where the TV is plugged directly into), from HDMI, to OPT and that doesnt seem to make any difference, and changed the sound profile on the TV from Auto 1, Auto 2 and PCM. Checked the CEC is enabled on the Amp, and it is.
I've tried different HDMI cables, and different ports on the TV and the amp with no success! Checked Bravia connectivity and that's enabled, but notice I get an ERROR_STR on connected devices, if I clear the log, it's only a few seconds before it displays again.
Amp plays other sources fine (such as bluetooth, radio etc.)
Any help would be appreciated :-D
