Sony Kd36nx200 Service Menu
Discussion in 'General TV Discussions Forum' started by jelly, Dec 29, 2003.
  1. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    anyone got a code that opens up this menu on this tv
  2. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    how can i disable the vps(vertical picture stabliser)
  3. fatbob
    fatbob
    May 22, 2003
    267
    19
    Hi Jelly,
    I'll be getting a new tv in the near future, and the NX200 is on my shortlist. What does the "vertical picture stabiliser" actually do, and does it affect the picture badly.
    Thanks,
    Bob.
  4. big10uk
    big10uk
    I also have this TV aswell.
    Great looking TV and crackin picture...
    If you have the service manual, or code, I would like it also...
    As every now and again, my Power LED flashes 12 times ?
    Big10UK
  5. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    mine too dont know why though
  6. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    i think the service menu is
    i +
    vol +
    number 5
    then the blue button
  7. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    hey big bob vps doesnt really da any thing bad just wondeder if it could be turned off great tv though
  8. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    shocking use of the english language
  9. big10uk
    big10uk
    Jelly,
    Ever thought about returning your TV as your LED is flashing 12 times...
    I have only had my TV under a month, and this is the only fault I can find?
    I asked the question before on another forum, and a bloke said that is was something todo with the onboard digital turner, and he recomended that I take it back to sony?
    Your thoughts....
  10. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    depends where you got it from and if youve still got the box to tell you the truth the led doesnt bother me that much
  11. big10uk
    big10uk
    Jelly,
    When did the LED start flashing for you?
    It happens about once a week for me, I turn the TV off and on and then it goes away.
    Big10
  12. big10uk
    big10uk
    *** Fix for 12 Flashing LED for KD-36NX200U ***
    If your power LED is flashing 12 times, use the following steps to resolve it:
    Turn off TV (Mine is a KD-36NX200U)
    From the fold down front pannel, hold down :
    "Prog +" & "Prog -" buttons
    Turn on TV (You will see "TT00" on the screen)
    Press "66" and your LED will flash.
    Press "00" to exit and your done.
    Hope this helps
    Big10UK
  13. bert69
    bert69
    Big10UK, thanks for the flashing led fix - my kd36nx200 has been doing this on and off since I've had it. Where did you find out about this fix and do you know what it does?
  14. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    hi strange question i know but here goes
    on this particular set on the back of the tv theres a plate that covers scart inputs (if u have the tv u will no what im saying) this plate fixes onto the tv by prongs which fit into 4 small holes on the back of the tv? into which there are 4 small black rubber things ivenot got any so my plate is just pushed in but due to a house move i need em does anyoneknow where i can get em from????? thanx
