Sony KD32NX200
Discussion in 'General TV Discussions Forum' started by seveer, Jul 2, 2003.
  1. seveer
    seveer
    Jul 1, 2003
    10
    South Yorkshire
    Hi all.
    I've just received a Sony KD32NX200 and I think it's blummin' marvelous ....... but then I'm new to all this digital tv malarky !
    The set is damn sexy IMHO and the picture looks fantastic sometimes and ok the next, maybe I need time to get used to the differences between it and my old JVC ?
    Anyway, does anyone else have one of these ? ........ offer any advice on setup etc ?? ........ Do's & don'ts ???
    reeves
  2. nathan_silly
    nathan_silly
    Reduce contrast from 100% to about 40-50%. Leaving at 100% will shorten the tubes life and increase possiblity of tube burn, and distort picture and generally look awful.
  3. WSH
    WSH
    Apr 13, 2002
    1,014
    28
    +39
    Take it off the "LIVE" picture setting which it is set to when you turn it on for the first time.
  4. seveer
    seveer
    Jul 1, 2003
    10
    South Yorkshire
    I have taken it off the *live* setting and put it on *personal* ......... I have also changed the contrast down to 40% ish as advised.
    The geometry of the screen looks spot on straight out of the box, and the picture looks great on certain programs and a little grainy on others ........ is there anything else I should adjust ?
  5. PaulJ
    PaulJ
    What sharpness setting are you using, this hsould be set quite low. I have mine about 10%.
    Paul :smoke:
  6. The_KELRaTH
    The_KELRaTH
    May 20, 2003
    100
    SurreyHeath
    +9
    I'm on my 3rd KD32Nx200 due to a fault in the scart control (no signal throughput when in standby).
    I find that setting the DNR to mid gets rid of any digital compression signal effects and is also very effective for cleaning up VCR tape image.
    The only thing I'm not too keen on is that dark images are almost black and bright images are overbright. I have looked through the service mode setting but can't find a gamma adjustment mode.
  7. WSH
    WSH
    Apr 13, 2002
    1,014
    28
    +39
    Do you mean grainy in which case is your aerial or pixelly in which case is the low bandwidth of digital programmes?
  8. seveer
    seveer
    Jul 1, 2003
    10
    South Yorkshire
    I've got the sharpness set at about 20% at the mo' ....... I'll try it at 10% and see how I get on.
    As far as 'grainy' is concerned ....... the picture is excellent 80% of the time on various channels ........... but then sometimes, it doesn't look as it should. It may be me ........ I'll keep monitoring it !!
    Overall though I'm very impressed with it's performance .......... 1 week in and no real problems to report.
    Except, the GUIDE button doen't appear to do anything ........ ???
