Sony KD32DX51 Question
Discussion in 'General TV Discussions Forum' started by Floydian1, Aug 4, 2004.
  1. Floydian1
    Floydian1
    Does anyone know if this tv can be set to default to an AV input when switched on? :lease:
  2. Breeza
    Breeza
    Oct 13, 2000
    115
    +7
    I expect its the same as the 28DL11 as the only difference is the styling, virtual dolby and svideo in the front panel.
    If you turn on the DL11 with a sky box (switched on) plugged into AV1 the TV always defaults to this input regardless of the channel last viewed. If the sky box is off when the TV is turned on it defaults to its own digital signal.
    Hope this helps.
  3. Floydian1
    Floydian1
    Nope, it always defaults to it's own digital/analogue signal what ever you do with the Sky Box.
  4. One-Cell
    One-Cell
    In the services menu on the Sky Digibox check that Scart Control is switched on. Hope this sorts your problem.
  5. Floydian1
    Floydian1
    Scart Control is on, the DVD player in AV2 will switch the TV over when you actually play a film but there's no response from switching the Sky Box on.
  6. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    Have you tried it with the DVD on AV1?
  7. Floydian1
    Floydian1
    Doh! what a dope I am. I had the scart plugged into the video out scart socket on the Sky Box!
