Sony KD32DX40 RGB Colour Problem
Discussion in 'General TV Discussions Forum' started by wyerd, Oct 25, 2003.
  1. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    Upstate New York. USA
    +27
    I've wired up my HCPC ATI monitor output to a Scart cable as described at http://www.idiots.org.uk/vga_rgb_scart/ and configured PowerStrip as instructed. However, when I connect it to AV1, the TV switches to RGB mode, but the colours aren't right - it's as if a magnet's been put to close to the screen. If I open the Write application which should be a screen of white, the middle of the screen is pink and the top is light green. I normally have Sky using AV1 RGB, which is fine.
    I've tested it on another Sony - KV14LM1U - no problems, so it can't be an issue with the wiring (I've re-wired & checked 4 times) or the graphics card.
    Is it a problem with the DX40 & can it be fixed?
    Thanks,
    David.
  2. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    Does anyone know what the problem could be?? Thanks.
  3. cosaw
    cosaw
    Jun 14, 2003
    753
    Stockport, Manchester
    +20
    Have you tried mailing the guy who wrote the article on the website. Got the DX40 myself but and although I like the idea the telly is too expensive to risk nuking it.
    cosaw
  4. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    Yes, but he couldn't figure out what the problem was. There really isn't a risk as long as you double check the wiring. It's just a disclaimer really.
    You'll need to wire the blanking control to the PC's 5V power supply to get the DX40 to switch to RGB if you give it a go. It's not that difficult as long as you have a steady hand with a soldering iron. Be interesting to see if you get the same problem.
    Cheers,
    David
  5. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    Anyone else have an idea what the problem could be? I'd really like to solve this so I can put all my HC kit into one HCPC box.
    Thanks.
