Sony KD28L10(U)
Discussion in 'General TV Discussions Forum' started by didgit, Nov 9, 2003.
  1. didgit
    didgit
    can someone tell me where I can find a list of codes to understand difference between sony models...some got an S at the end which I believe means stand included (thanks to simon1) now I've come accross the Sony KD28L10 and KD28L10U what on earth does the U stand for ?
    please let me know if there is a site which explains it all, I've had a look at the Sony web site but can't find any info there.
    Thanks in advance
  2. blackhammer
    blackhammer
    Dec 18, 2002
    320
    +7
    I though the (S) at the end of the model stood for silver in coulour. Maybe i am wrong. Either way it's all very confusing!
  3. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    The 'U' is simply the country code - ie for televisions destined for the UK.
    Most retailers wouldn't necessarily quote the 'U' in their adverts, but would be selling a 'U' version.
    A small number of retailers may sell 'grey imports' - eg they would buy their stock from Sony in another country, rather than from Sony UK. This may work out cheaper for them and they could pass on a saving to the customer. The tv may then have a different letter after the model no.
  4. didgit
    didgit
    thanks again simon1 for the advice, hopefully that's the last Sony code I get stuck with.
    cheers
