hi there. i've got the 32" version and am pretty pleased with it. i have only experienced very slight ghosting on mine, not particularly on credits, but i'm fairly sure it was only on an analogue channel. strongly suspect this is down to my aerial which i'm trying out in the loft. (not ideal but i'm too tight pay someone to get to the top of my roof). No ghosting at all on dvd, Are you using a good quality scart? I'm using a thor for £18 inc del as recommended on these pages from play.com. If it were me i'd be disconnecting everything thats not necessary on your set up and see what happens. Other than that it's too technical for me! I do have one picture issue on mine, left hand side of the screen, when a brightly coloured background (often blue) moves, it seems to seperate into short horizontal lines and flicker until movement stops again!!?!? Do you get this? Anyone? Dvd is sony davsc5. I should try the other dvd player that came with the telly. Anyway good luck with it, see ya bockster
