Sony KD28DL11U CAM slot
Discussion in 'Televisions' started by raydawson, Dec 27, 2004.
  1. raydawson
    raydawson
    Nov 26, 2004
    232
    28
    UK
    +27
    I've just bought a Sony KD28DL11U and the picture quality is superb.
    But, on Sony's web site it says the KD28DL11 has a PCMCIA CAM slot for Top up TV. I can't find it on mine. Is it hidden behind anything?
    Cheers,
    Ray D
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    :rtfm:
    It should be in there - there is a cover on the back which protects it! :rtfm:
  3. raydawson
    raydawson
    Nov 26, 2004
    232
    28
    UK
    +27
    Ah, found it. Item 8 on page 26 shows a greyed out cover saying 'for future use only'. As Top Up TV is now with us, I wonder if the 'future use' is here yet.
    Thanks a lot Martin.
    As a matter of interest, do you have a small hum bar on your screen? On the right side of the screen there is a small hum bar - well a line really - which travels up very slowly. It's there with any input selected.
    Cheers,
    Ray D
  4. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Yes that is DEFINATELY the CAM slot :thumbsup:
    Hum bar well there are things to try
    If it is on DTTV turn off any plugged in thing.
    If it is on DVD switch the TV to analogue before DVD.
    Reason is that RGB out is available from Scart 1 and there is a possibility of cross talk.
    Future use - well it didn't use to be as I had an Ondigital CAM
