sony kd 36nx200
Discussion in 'TVs' started by luv ya jen, Jul 7, 2003.
  1. luv ya jen
    luv ya jen
    had my sony 4 about a month and noticed that on ws films the screen is bowed like a rainbow and on sky sports news the scrolling banners and text on the left and right of the screen are pointing slightly up any help before i ring techtronics???????
  2. WSH
    WSH
    Apr 13, 2002
    997
    28
    +39
    Horizontal geometry like that cannot be adjusted. Only vertical bowing etc.
  3. luv ya jen
    luv ya jen
    so how do i sort it???????
  4. Christ
    Christ
    Dec 15, 2002
    275
    Yorkshire
    +18
    As far as I know the only way is to replace the TV or
    change the tube. Before you worry though I would go
    Into a showroom and look at any TV 32” or above, most (if not all!) will have a slight upwards bow, especially on Sky menus etc.
    How many mm is the bow?
    Chris
  5. WSH
    WSH
    Apr 13, 2002
    997
    28
    +39
    You are likely to get lots more issues if the tube is changed going from those here who have had theirs changed.
  6. luv ya jen
    luv ya jen
    the bow is 11-12mm
  7. Christ
    Christ
    Dec 15, 2002
    275
    Yorkshire
    +18
    Thats pretty big.. Looks like Sony quality control at its best yet again!! Think ours is maybe 3/4mm which isnt so noticable.
    If it bothers you send it back.. as Im fairly sure theres no way of altering it in the service menu..
    Anyone else?
  8. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    I think it can be controlled with stick on magnets.
    A GOOD engineer should be able to fix it.
    Who would pay extra for perfect geometry?
  9. WSH
    WSH
    Apr 13, 2002
    997
    28
    +39
    I would imagine stick on magnets could cause secondary problems with colour staining.
  10. luv ya jen
    luv ya jen
    had a engineer come out and he told me that the tube was to blame told me that i could get the scan coils reset?????? but i would lose some of the detail on screen charged me £25 and promptley left phoned them to see if he had got in touch with sony and he said that SONY had told him that a bow like this was in reasonable state (basically live with it) but i went down to the sony ctr in notts where they have a set on display snd lo and behold there picture is perfect even on sky ( think ill get in touch with techtronics for a replacement tv)
  11. andya
    andya
    Oct 25, 2002
    2,391
    48
    manchester
    +26
    you should have gone to john lewis 5 year warranty and they will change the set without batting an eyelid ive had 5 sonys and after the 5th i got my money back.geomatry was ok on mine it was other problems i had
  12. luv ya jen
    luv ya jen
    not even had it a month!!!!!!!!
  13. Radiohead
    Radiohead
    Dec 24, 2001
    4,295
    Amazingstoke
    +433
    Get it swapped out then - asap.
  14. mansell
    mansell
    Feb 11, 2002
    754
    28
    Bristol
    +39
    actually what you need to do is adjust the magnet's (which are already attached) on the back of the tube .
    This should really be done in a w\shop .
    I have a Horizontal deviation of about 3-4mm , vertical is 0mm
  15. WSH
    WSH
    Apr 13, 2002
    997
    28
    +39
    I had 4 sonys from john lewis before a refund too.
