Sony KD-28DX50 question
Discussion in 'General TV Discussions Forum' started by mattius, Feb 1, 2005.
  1. mattius
    mattius
    My Sony KD-28DX50 TV has done the following since new.
    When TV is first turned on the screen is Black for about 4 secs. Then very briefly the screen shows some green banding before the picture comes up. This lasts about a second and then the picture is normal. What I need to know is do I have anything to worry about or is this fairly normal, & if so why does it do it. A friend said it was the initial energisation of the tube??????
    If anyone can advise I would be grateful as things like this stress me out. :confused:
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Hello Mattius and welcome to the Forum. :)
    No, there's nothing to worry about. :clap:
    All picture tubes need a little time to warm up and stabilise, that's why they're blanked out for a few seconds.
    (When TG was a lad, the valves in the TV's of that era took about a minute to warm up and so the problem never arose.)
    If your blanking period was just a second longer, you'd never have noticed the effect.
  3. mattius
    mattius
    Thanks - Phew! :thumbsup:
  4. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    mattius,
    My KD28DX50 does the same. Incidentally, do you get any vertical coloured bars on the screen when using the integrated digital tuner - I get green bars, hence the name (TV soon to be fixed, I hope).
