Sony input switching,
Discussion in 'General TV Discussions Forum' started by Rob, Jul 22, 2001.
  1. Rob
    Rob
    Jul 17, 2000
    1,285
    Norwich
    +33
    Hi All,
    Trying to help out a friend who has a Sony Vega W/S TV (don't know the model).
    After power up, it switches to AV2 , Have tried various settings in the output/ screen menu but nothing seems to make any difference. Not having the manual doesn't help. Does anybody know how to cure this?
    Thanks Rob.
  2. Darren_L
    Darren_L
    Jun 30, 2001
    96
    England
    +3
    I agree with Nike. The TV will switch automatically to an AV input when the device connected to the AV input is switched on, or play pressed etc.
    If there's nothing connected, then try changing the channel on the TV back to a non AV channel then switch off. Switch back on and see what happens. Some TVs remmber which channel you were watching and then switch to this when you turn back on. If it still changes to the AV input then I dunno :( .
    Try to find the model (it's on the back somewhere usually)
  3. Rob
    Rob
    Jul 17, 2000
    1,285
    Norwich
    +33
    Thanks chaps,
    There is a DVD player plugged into AV2, and Skybox into AV1. It would just be a case of changing the scarts round, but AV2 doesn't support RGB. On power up, you are just greeted with a blank screen showing AV2. I'll play around a bit more. If you do think of anything else let me know.
    Thanks again Rob.
  4. Nike
    Nike
    Feb 27, 2001
    667
    bournemouth, UK.
    +20
    Is there anything plugged into AV2?
    My sony w/s will switch to AV2 a soon as the VCR plugged into it is powered up.
    If there is nothing connected, then I don't know I'm afraid.
