Sony Idtv Software Update
Discussion in 'Satellite TV, Sky TV & FreeSat' started by simon1, Dec 24, 2003.
  1. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    The following models are to be given a new software update (version 3.00), to solve problems with BBC multiscreens, etc.
    DX40, DX100, NX100, DX150 & NX200
    The update will commence on 29/12/03 and continue until 05/01/04
    Leave the set tuned to one of the BBC channels for a couple of hours during this time. After the download, switching the set off/on will allow the new software to take effect.
    Information taken from DTG website
  2. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    any one know how much a wide band aerial would be for a sony 36"nx200
  3. phenom2003
    phenom2003
    Installing yourself or by an aerial installer?
    A profesionally installed one by an aerial dealer would cost between £60 and £120
    Doing it yourself however saves alot of money and can be had for about £20 to £25 (although if you don't know what you are doing it can be VERY dangerous) from places like Maplins and TLC direct, a quick search on the maplin site shows one for £20 code no. MZ40T.
    If you decide to have it installed profesionally use a member of the CAI, theres a search function on the site to find a local installer.
    Rich
  4. Fernsehman
    Fernsehman
    The TV doesn't matter. It depends on your location and the signal strength of your transmitter.
    Once you know what type of aerial you want (selected on the basis of desired gain, immunity to interference etc.) then you can check out prices on pages like this one.
  5. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    how do i find out where my nearest transmitter
  6. big10uk
    big10uk
    *** Fix for 12 Flashing LED for KD-36NX200U ***
    If your power LED is flashing 12 times, use the following steps to resolve it:
    Turn off TV (Mine is a KD-36NX200U)
    From the fold down front pannel, hold down :
    "Prog +" & "Prog -" buttons
    Turn on TV (You will see "TT00" on the screen)
    Press "66" and your LED will flash.
    Press "00" to exit and your done.
    Hope this helps
    Big10UK
  7. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    19th to 26th January for first generation sets
  8. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +266
    Martin
    What do you class as a first gen set? I have a kp-41ds1 v 2.13
  9. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Yours!
    KVnnDX20
    KVnnDS20
    KPn1DS1
    KVnnDX30 (early)
    All use same tuner
    KVnnDS60 use a similar one
  10. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +266
    Thanks Martin.
  11. Rojo Habe
    Rojo Habe
    Oct 20, 2003
    138
    +3
    Wow
    I'm glad I just happened to stumble across this, just two days before the update. Since I tend to watch Freeview only when I'm recording cable, there's every chance my set could be tuned away from a BBC channel for months at a time. I s'pose it could be argued that I don't really need the upgrade in this case, but one likes to have the latest. :cool:
    I'm curious - what happens if, not knowing anything about this, you happen to miss the window. Is there any way the set will get the update, or do you just have to wait till another one is released?
  12. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +266
    I have tried to update my Tv for the last two days without success :(
    I even received an email from Sony confirming the upgrade dates as being the 19th to 26th January.
    Has anyone had any updates yet?
  13. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    You know that you need to leave the set tuned to Digital BBC 1 for about 2hrs.
    After that, turn the set off, then back on again to complete the update.
    You should now be able to confirm that the software version no has changed.
  14. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +266
    My tv was left on BBC1 for 4 hours each day.
    So has anyone had any success wth updating thier set???
  15. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    If it didn't update call Sony for a card
  16. BWFCian
    BWFCian
    I have a Sony DX150, updated the software but couldn't get the multicreen news etc to work.
    You need to manually tune in channel 701 702 & 703.
    works fine :clap:
  17. Zane
    Zane
    I have a Sony KV32DX30 idtv, will this updated software cover this model.
    If so, does the electronic programme guide change its version number? Mine currently states V1.01.
  18. leesbriggs
    leesbriggs
    V1.01 is very out of date! Mines been updated 3 times since that release! Mines currently on 1.08, but that was done probably 6 months ago, so not sure if there is a new update. I would contact sony and get them to send out an update card. You obviously can't get a picture on parliament?
  19. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    My dads DS60 upgraded to 4.96 today
    Multi screens still don't work
  20. Zane
    Zane
    How can you tell when this software has been downloaded ?
    Left my DX30 on for 3 hours plus yesterday and cannot find any difference. I'm receiving pictures from the Winter Hill transmitter.
  21. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +266
    I also receive from Winter hill, but I still have not received my upgrade. The software version on my TV is on the EPG page in the top right hand corner.
  22. big10uk
    big10uk
    I have a Sony 36-NX200U TV (UK)
    And my software version are:
    Software: 3.00
    Loader: 1.01
    Are they uptodate, or are they any later versions out ?
  23. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    Yes, 3.00 is the latest. It was broadcast at the back end of December.
    One thing I noticed is that the games work properly now. Previously, when playing 'Tetris', it took about 10 seconds for one of the blocks to move a single step.
  24. Rojo Habe
    Rojo Habe
    Oct 20, 2003
    138
    +3
    If you leave it tuned to BBC1 while watching AV1, will it still update?
  25. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    No
  26. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +266
    Sony (newer sets) IDTV2 updates are available on the 22nd. My set failed to update the last time the updates were transmitted so i emailed Sony at the weekend asking for an update card, which they are glady sending. I am currently on version 2.13 but I don't know if I am getting 2.14 or a newer one.
  27. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +266
    I am now running 2.14, but I don't know what the changes were. does anyone know what the update contained???
  28. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    2.14 fixes The Hits service number
  29. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +266
    thanks... I did loose that channel the last time a did add channels.
  30. dac
    dac
    Jul 6, 2002
    422
    London
    +15
    hi all,
    does anyone have a contact email address or or number for requesting sony updates?
    i've never carried out updating it using a card, so steps/instructions will also be greatly appreciated.
    i haven't updated mind for over a year and a half on my dx100. still love the picture quality of this set. :)
    cheers,
    dac
