tigerstyle25
Hi there,
I have an ICD-UX80 recorder, which I used once and it worked well.
However, the next time I went to use it, the loading bar went across the screen and then froze at the end.
Does anyone have one of these, and could you send me the root files by email so I can try and reset it?
There's no manual reset for this unit. If anyone has any other ideas I'd be very grateful.
Thanks!
David
Thanks!
David
