Sony HXD970 - series link option gone?
Discussion in 'Blu-ray & DVD Players & Recorders' started by GreyArea, Jun 17, 2008.
  1. GreyArea
    GreyArea
    Jan 30, 2007
    33
    +4
    I've just run into a small problem with my Sony HXD970 - if I try to record something off the guide (digital) it no longer allows me to select Series Link - it's just got '-----' next to it and can't be selected with the up/down controls.
    Any idea what causes this?
    (I'm away for a few days so may not get chance to reply to this for a week)
    Jim
  2. GreyArea
    GreyArea
    Jan 30, 2007
    33
    +4
    Additional info - this seems to have happened after the aerial got unplugged for about a day-and-a-half. It's also had a complete power-off/on.
    Does series link only appear after the digital guide has updated for a while? I only ask because two series linked series that were already programmed in are still there and seem to be fine. I just can't seem to create new ones.
    Jim
  3. ramjet
    ramjet
    May 21, 2006
    3,761
    +622
    it may well depend on it being flagged on the epg
    and make sure you are using the latest sony firmware in your recorder too
  4. GreyArea
    GreyArea
    Jan 30, 2007
    33
    +4
    Thanks - I think I was just unlucky enough to pick programmes that weren't flagged by the network properly. All seems fine now.
