Sony hx15 problem?
Discussion in 'General TV Discussions Forum' started by meath man, Jan 24, 2005.
  1. meath man
    meath man
    Jan 12, 2005
    598
    meath
    +7
    Has anyone else had this problem with their sony hx15 ( im thinking of getting the 28 inch version?
    ''My advice is don't buy it. Although it has perfect geometry (for football) it has an annoying feature called scan velocity modulation which you can't turn off. Trust me it throws up a surprising glow around bright objects which can make some weird spotlight effects appear on the screen for a few seconds. . The hx15 was close but at the end of the problem i described (weird as it is) added with the slight hint of red on the left handside and yellow on the right handside (noticable uring white backgrounds)''
    This was advice i received from another member of the forum.
  2. timbo_bobcat
    timbo_bobcat
    Aug 13, 2004
    I've had an HX15 since Sept and have noticed no such thing.
