Sony HX1000/900 vs Panasonic E95
Discussion in 'Blu-ray & DVD Players & Recorders' started by dvdkid, Jan 23, 2005.
  1. dvdkid
    dvdkid
    Hi All
    I can't decide between the hx900/1000 and E95,
    Can someone list me some pros and cons about these 2 players, my prios are
    :lease:
    Good PQ
    Easy to Use -> Navigate
    Schedule recordings
    Pause live tv easily (heard this was complicated on the E95??)
    Editing recordings, how bad is the Sonys really ???
    Any useful info about these 2 players are welcome...
    Tnx
    dvdid :clap: :thumbsup:
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,708
    Warwick
    +2,584
    Both machines are easy to use and offer similar PQ (when dubbing to DVDR at lengths over 2hrs the Panasonic offers significant advantage in PQ due to maintaining high res). 'Timeslip' is roughly equivalent on both units.
    The Panasonic has the edge in editting though without a doubt. The Panasonic's provide various tricks and a slick interface for accurate edits either by non-destructive playlists or partial erase. On the HDD the Sony only offers Partial Erase (A-B Edit) and this is further hampered by the controls. There is also no Divide function - the absence of which you should not under-estimate.
    If your after general DVD recorder advice have a look at the 'Which DVD Recorder?' link in my signature!
  3. S Helton
    S Helton
    Oct 29, 2004
    68
    +4
    If you need to archive 2hr+ recordings from HDD to DVD, the Sony is not the answer. The editing functionality is extremely limited.
    If you just want excellent picture quality to watch a recording a few times and then erase it, the Sony is a good choice. DVD playback is also very good.
  4. BillTheButcher
    BillTheButcher
    Jan 7, 2005
    149
    +8
    I had to make the same decision as you a couple of months ago.
    I finally decided on the Panasonic for the reasons listed by Rasczak. :thumbsup:
    Buy the E95. You won't be disappointed. ;)
