Sony HX 510 component
Discussion in 'Blu-ray & DVD Players & Recorders' started by kingsize, Sep 18, 2005.
  1. kingsize
    kingsize
    Jul 16, 2004
    1,038
    +49
    Hi folks.
    Could anyone advise as to how to turn off the scart output in order that i can turn component output on?
    Will this affect my loop through and recording of sky etc? cabling is sky -> sony -> plasma
    I am totally befuddled...any help would be great
  2. Starfury
    Starfury
    May 5, 2005
    99
    +5
    Not at home right now to go through the menus precisely, but I believe it is in the 'SetUp' option of the main menu, under 'Video' subsection is 'Component Out:' and you set that to on.
    It wont disable Scart output, just RGB output through Scart 1.
    Scart inputs should be left ok for recording from Sky, but as I dont have Sky I cant say for certain.
