Sony HX-1000 Dubbing Problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by Krudler, Aug 27, 2005.
  1. Krudler
    Krudler
    Jan 25, 2005
    58
    Apologies if this has :( been raised before.
    My HX-1000 has just developed a problem when dubbing from the HDD to a DVD. It shows the error message C13:00 (disk is dirty) and then powers off and restarts etc...
    I have tried two different manufacturers of the DVD-R disks and it happens on both. I'll try DVD+R and maybe a DVD+RW tomorrow but if anyone else has seen this problem I would love to know if it needs to be repaired.
  2. Chris at Home
    Chris at Home
    It might not be the disc. It could be the laser reading head. I bought the HX 900 in February and, as yet, I have never cleaned the "eye" nor any of the discs.
    But then, I'm a good boy who always washes his hands after I have been doing anything messy! ;)
  3. Krudler
    Krudler
    Jan 25, 2005
    58
    Chris,
    Thanks for your reply. I did try a DVD+R the following day and had no problems at all. It's funny that I have just bought two different batches (and makes of DVD-R, Imation and Philips) and have the same problem with both.
    Not sure how to clean the "eye" but I'll try and figure it out. Also might buy some of the original DVD-R's (Verbatim) and see if that cures the problem.
    Thanks anyway
  4. peejay2
    peejay2
    Mar 12, 2005
    23
    I'm having a similar problem on a Philips DVR 75. The image is sometimes jumping or freezing, and the same discs are working perfectly on another reader. It is in a living room by a fireplace, so I guess it is very easy that smoke dust has gone onto the lens.
    Neither do I know if there is a method to clean the lens, other than going to the Philips service.
    Peejay
  5. Krudler
    Krudler
    Jan 25, 2005
    58
    Well I bought some new Verbatim DVD-R disks and the dubbing problems have gone away.
    It seems therefore that the Sony RDR-HX1000 does not record or dub correctly with either Philips or Imation DVD-R disks.
    Krudler
