Sony HTSS1300 - Help!!
Discussion in 'Home Cinema Buying & Building' started by chuchuj, May 28, 2008.
  1. chuchuj
    chuchuj
    Jun 29, 2006
    126
    From what I can gather the Sony HTSS1300 has 3 HDMI inputs and 1 output.
    Does this mean I could plug my PS3 and 360 into it via HDMI, then to my TV with the output? Also would still allow me 5.1DD?
    James
  2. Pincho Paxton
    Pincho Paxton
    Oct 3, 2006
    14,125
    +634
    yes.
  3. Richard
    Richard
    May 19, 2008
    11,405
    +1,620
    I was thinking about doing that too.
    So will the hdmi cable carry the sound also so there's no need for the optical lead as well?
  4. Strom
    Strom
    May 7, 2008
    17
    3
    yes.
  5. adam-james
    adam-james
    Apr 10, 2008
    15
    Odd. I was told, by the sony store, that I'd need a opticial for the sound.
    I hope they are wrong... still waiting for my HTSS1300 to turn up, so I'll hopefully know the answer soon.
    I don't see why not. I plug the ps3 into the w4000 and the sound is just fine... apart from missing that 5.1 goodness!
  6. stefanr
    stefanr
    Dec 2, 2007
    1,004
    The Home of English Rugby
    +61
    I wouldn't listen to what they say as they generally know jack (franchises).
    HDMI will pass sound and video at 1080p.
  7. Richard
    Richard
    May 19, 2008
    11,405
    +1,620
    I tried to do that last night but struggled to get it working.
    At the moment I've got my ps3 plugged into the bd input.
    Got the 360 plugged into the first optical input and sky hd into the 2nd.
    Last night I tried removing the optical cable for the 360 and plugging the hdmi into the dvd input. I couldn't get sound or picture.
    Anybody know what I'm doing wrong??
    Thanks.
  8. shenryo
    shenryo
    May 30, 2008
    61
    sorry i cant help pal
    however, this system offer high def sound doesnt it? what kind? one site says it has the best on offer, Dolby True HD, another says this is not the case
    any ideas folks?
  9. Wightknight
    Wightknight
    Mar 8, 2008
    13
    In a sense they are both right. The system will play HD sound but it can't decode it. The decoding has to take place on the source component.
    This means that your BD player or PS3 would decode the HD sound from the disc then send it as a Linear PCM signal to the amplifier which can then produce the sound. It is important to make sure that the sound output on the component is set to Linear PCM and not bitstream.
  10. Wightknight
    Wightknight
    Mar 8, 2008
    13
    Have you solved this problem yet? It is likely to be something really simple that will leave you kicking yourself.
    The first thing I would check is the HDMI cable. Is it properly connected? Is it the right way round? (They are directional and there should be arrows on the cable telling you the direction the signal will flow i.e. from Xbox to amp.)
    If that doesn't work, try the HDMI cable in another socket on the amp.
    It is also possible (but unlikely) that the HDMI cable has developed a fault. Try using the cable from your PS3 and see if that works.
    I hope one of these works!
  11. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    thats not right at all..
    there is no hdmi cable in the world that is one way,they are uni-directional,as connecting the cable any way will result in it working.
  12. shenryo
    shenryo
    May 30, 2008
    61
    so, when I switch between components will i have to keep changing the sounds on them? i.e. when watching a blu ray i have LPCM, but when finishing with that and switching to Sky, will i then have to change something on the tv?
  13. shenryo
    shenryo
    May 30, 2008
    61
    also, I have heard that thew rear speakers offer 4.5m of cable - any idea how easy these will be to extend to about 8m? by doing this, will there be any loss in quality?
  14. jwindley
    jwindley
    Jun 20, 2007
    218
    +12
    I believe changing to LPCM would be a setting on your blueray player, not the ht-ss1300. If you set your blueray to output LPCM, and your sky to output DD through optical, all should be good. The amp will simply detect the data being sent to it, and output / decode it as needed.
  15. Welsh Whirlwind
    Welsh Whirlwind
    Mar 15, 2006
    1,888
    +243
    Basically you need to set your PS3/BD player to output sound over HDMI, and use the following settings:
    LPCM for Blue Ray Discs
    Bitstream for normal DVD's
    I believe the PS3 has some sort of auto setting that might select these automatically depending on the disc? - I maybe wrong... A PS3 owner can clear this up.
    AN Important anp setting to check if you are having trouble getting sound/video over HDMI is this:
    Menu, select '6 Video'
    Select 'Audio'
    Select 'Amp' NOT 'Amp and TV'
    Then,
    Set your AMP to 'A.F.D. auto' by pressing the AFD button on the remote repeatedly.
    Make sure your amps decoding priority (Dec.Pri.) is set to auto, not PCM.
    Menu 5 'Audio'
    Select 'Dec Pri'
    Select 'Auto'
    Notes:
    1) When you stream HD uncompressed LPCM to the amp or your sampling frequency is higher than 48khz so you will not be able to change any of the soundfields by pressing the 'Movie' button on your remote. It will display 'Not Used'
    2) When bitstreaming into the amp all soundfields are available and DD5.1/DTS should light up on the amps display as long as your amp is set to 'A.F.D. auto', so, choose either 'A', 'B' or 'C' once the film has started. Remeber DTS soundtracks have to be choosen manually on the DVD's own menu and will not be auto-detected.
    3) If you have messed around with alot of settings or are having trouble, factory reset the amp by holding down the power button on the amp for more than 5 seconds.
  16. Wightknight
    Wightknight
    Mar 8, 2008
    13
    Hi RottenFox,
    Could I invite you to look at this website? http://www.chord.co.uk/chordweb/chord_hdmi_silver_plus_technical.htm
    These are the cables I use. It may well be that some other brands are less fussy.
  17. Welsh Whirlwind
    Welsh Whirlwind
    Mar 15, 2006
    1,888
    +243
    My 1200 came with 8m surround cabling, so did the earlier 1100 model. So I can't see why the 1300 would come with a ridiculously short 4.5m...
  18. shenryo
    shenryo
    May 30, 2008
    61
    i thought that was rather poor myself - found that info from Sony website - hope I am wrong though
    anyway people, time I am here: have just had Sky HD fitted this morning and the Sky technician recommended I purchase better HDMI cable than the one provided from Sky - can anyone verify that this is necessary for best results? If so, any recommendations at decent prices, and, would this also be the case with PS3?
  19. Bassy
    Bassy
    Mar 7, 2008
    3
    This is my first post after a long time watching and reading. I bought the 1300 at the weekend from my local Sony store and the guy who sold it to me said the surround cabling was 10 metres. After setting it up I would have to agree it was around 8 to 10m. I had an awful lot left.
    I'm not an expert in home cinema but the system seems very good to me especially through my PS3 and Toshiba HD E1! I am a happy customer. It was also a lot cheaper than the Pioneer LX01 I was looking at.
    Tom
  20. stefanr
    stefanr
    Dec 2, 2007
    1,004
    +61
    I got mine from HERE
    Go for the Premium range, good prices as well. :thumbsup:
    Others with no doubt plug their own suppliers, dreadful pun :eek:
    I brought my PS3 from gamestation bundled with a game and two BD discs for £315 but whatever you do go to the shop and not online, had to wait a week for mine.
  21. Richard
    Richard
    May 19, 2008
    11,405
    +1,620
    No, just tried again and it still won't work.
    Made sure all the leads are in properly too.
    It can't be a lead as the out lead out works fine for the PS3 and the 360 lead i have been plugging into the surround sound system works fine if I plug it straight into the tv.
    Any ideas???
    Thanks.
  22. Welsh Whirlwind
    Welsh Whirlwind
    Mar 15, 2006
    1,888
    +243
    Have you done/tried everything in my post on page 1?
  23. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +4,289
    what a load of trash...and paying the prices they want for a cable..crazy.!
    yes,gold plating,always helps transfer the digital data better!!:rolleyes:
  24. shenryo
    shenryo
    May 30, 2008
    61
    ahhh one more thing folks; with regard to the optical cable fro Sky HD sound into 1300, does Sky already have one of these cables, or, can one of you guys recommend one for me?
  25. Richard
    Richard
    May 19, 2008
    11,405
    +1,620
    I'm pretty sure that's how I've got the system set up now. Was having trouble getting DTS out of it but that's all sorted now.
    Will double check these settings over the weekend though.
    Cheers ww.
  26. alexs2
    alexs2
    Nov 13, 2002
    13,961
    +1,671
    It should be noted that whilst many manufacturers make claims about the directional nature of their products,(and this includes Chord,Kimber and many others),that there is little if any scientific evidence to back this up with.
    RottenFox's comment...
    ......Is entirely correct,and the cable WILL work whatever way round it is connected....this also applies to any number of so-called directional interconnects and speaker cables.
    I appreciate that the reply..
    may seem forceful,but I am sure that this reflects the feeling that directionality is an often-used marketing tool,along with many other techniques.
    I am sure that the moderator concerned will reply in time also.
  27. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +4,289
    my post was never to infer that Chord cables were trash,merely that following the posters point that i take a look at the site,and see for myself/to read the article, i did.
    and so after reading, i didnt agree with it.
    I should have possibly said,"I don't believe that to be factually correct".
    These past few posts,once again,airing the view that cables are an emotive subject.
  28. Bleeders
    Bleeders
    Jan 16, 2003
    1,064
    Grays, Essex
    +48
    I've been naughty and gone for one of these to replace my broken Denon 500SD, couple questions though; is there a DVD built into it?
    Secondly, I went for the SS, but I would prefer stands for the rears only, any decent universal ones knocking about?
    S
  29. teapot1971
    teapot1971
    May 15, 2008
    83
    +8
    hi just got my htss1300 from empire direct had to wait 5 weeks because my htss1100 order got cancelled got the 1300 for £235:clap: for waiting so long
    my question is what have i got to change on my ps3 in sound settings and could anyone show me there on screen sound settings on there ps3 this would be a great help thank you
  30. axe_1986
    axe_1986
    Apr 9, 2008
    178
    +57
    No built in dvd mate, its the broken down packages just the reciever and speakers
