sony HTSL5 vs HTK25
Discussion in 'AV Receivers & Amplifiers' started by Foxey, Jan 5, 2003.
Tags:
  1. Foxey
    Foxey
    about to buy my first surround sound kit. been reading the previous thread about the HTSL5 but wondered how this compared against the HTK25. usual things such as what connections has the HTK25 it got (get the impression things made be routed via the sub) and does it get as hot at the htsl5 as i concerned that i may not have enough air in my corner of the room, under tv is already fairly cramped with video, dvd and cable tv.
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,896
    71
    50 Rue St Georges, Paris.
    +27
    If you don't need radio, HT-K25 is a little more powerful and more compact than HT-SL5. The matching DVP-F25 DVD player makes a neat combo.
    I wouldn't worry about heat issue with either model.
  3. Mark Spanner
    Mark Spanner
    Dec 11, 2002
    264
    Norfolk, UK
    +5
    Or the fan noise!
    When you've got any sound going it isn't an issue.
