Sony HTK250 Replacement Cables - Where?
Discussion in 'Cables & Switches' started by fuzzb, Jul 27, 2005.
  1. fuzzb
    fuzzb
    Hi, I have the Sony HTK250 5.1 Home Cinema kit (http://www.avland.co.uk/sony/htk250/) and I was wondering if anyone knew where to buy replacement cables from? I tried looking at some online stores but couldn't find the type of connectors needed for the system. The connectors look something like:
    [x] [x] (this is looking head on)
    where 'x' is the speaker cable. It's a plastic connector about 1cm long with two holes where the wires go. This then fits into the receiver quite snugly.
    Any info much appreciated :)
