Sony Htk25 Home Cinema Trouble
Discussion in 'Home Cinema Buying & Building' started by jimmysdisco, Jun 17, 2004.
  1. jimmysdisco
    jimmysdisco
    Jun 17, 2004
    10
    3
    hello can anyone help? My sony HTK :lease: :lease: 25 home cinema system has just died no power checked all fuses and ok it does not light up just stopped working.
    has anyone had this problem or is it time to get a new system.
    If i cannot repair it i am looking at buying sony sc6, anyone got one and do you recomend it,or do I go for sc8
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,101
    notts.
    +73
    Hi jim
    Does the sub power up or is it just the proccessor not getting power.
    Have listened to the sony all in ones in currys when my old man wanted a system. In the end he took my advice and went for the yamaha htibox system which he paid £370 it made the sony systems sound crap plus makes it easy to upgrade and being seperates you dont lose the whole system if any failures occur.
    Cheers Gonzo. :)
    Jim check the umbilical cord between the sub and the proccessor if its out at either end the unit will not switch on.
    Ive just checked on my daughters unit in her bedroom if the umbilicals plugged in ok you may just need a new cord.
  3. jimmysdisco
    jimmysdisco
    Jun 17, 2004
    10
    3
    No Power To Sub Or Control Unit ,the Umbilicle Chord Is In So Maybe Thats Faulty
  4. matty2767
    matty2767
    silly question but have you checked the fuse?
  5. jimmysdisco
    jimmysdisco
    Jun 17, 2004
    10
    3
    Yes First Thing I Checked Internal One Aswell Anything Else Is Beyound My Knowledge
