Sony HTDDW860
Discussion in 'Home Cinema Speakers' started by cojeh, Jul 25, 2004.
  1. cojeh
    cojeh
    Looking to buy the Sony HTDDW860 but need to know it has the connections I need. They are listed at
    http://www.avland.co.uk/sony/htddw860/htddw860.htm
    but I'm not quite sure what to make of the table as my technical knowledge is limited!!
    I currently connect my computer to my present hifi via the AUX, I am confused as to whether AUX is the same as LINE IN, they are red and white phono leads (I think). I want to know I will also be able to do this with the new system.
