Sony HTDDW860 Home Cinema Package
Discussion in 'AV Receivers & Amplifiers' started by Peter Kendrick, Jan 1, 2005.
Tags:
  1. Peter Kendrick
    Peter Kendrick
    Jan 1, 2005
    65
    I am new to Home Cinema and was thinking of buying this package. Can anyone let me know what it is like or offer a better alternative. The package comes around £250 for a receiver and 7.1 700watt speaker system.
    Thanks.
  2. harrison99
    harrison99
    The Sony set-up has limited connections on the amp - e.g. no component video or S-Video capability, so you could not use the amp for switching purposes. The following link details the connections:
    http://www.avland.co.uk/sony/htddw860/htddw860.htm
    If you are prepared to spend a bit more then you could have a Denon AVR1705 amplifier for around £200 (with loads of connection possibilities) and some Canton CD-1 speakers if you import them from Germany (again around £200 - there are loads of threads on importing the Cantons on AV Forums).
    Another option to consider - especially if your DVD player is not very good - is the Denon DHT550SD all-in-one system. This gives you a progressive scan DVD player, tuner, CD player, amplifier and some cracking 5.1 speakers for around £400. It is reviewed on the following link:
    http://www.homecinemachoice.com/cgi-bin/outputpdf.php?file=WVTV/200410/034_WV_1004.pdf
    The Sony appears to be a 6.1 system - have you thought carefully about the location of the back speaker? They can be difficult to place if, for example, your sofa backs on to a wall.
    Hope this helps
  3. Peter Kendrick
    Peter Kendrick
    Jan 1, 2005
    65
    Thanks very much Harrison. I will research your suggestions. I was thinking of buying the Sony HX900 DVD/HDD recorder, however, there appear to be problems dividing the recordings.
    Happy New Year!
    Peter Kendrick.
  4. harrison99
    harrison99
    Good luck with your research, but if you're going to spend around £550 on a DVD/HDD recorder then I think you should spend more on an amp and speakers to realise the benefit of that investment.
