SONY HTCT260 vs HTCT60.CEK
Discussion in 'Home Cinema Speakers' started by andyodell, Aug 13, 2013.
  1. andyodell
    andyodell
    Jun 26, 2006
    34
    I have been looking at these 2 sound bars. I just missed a very good price on the HTCT260 which has now made me look at hte HTCT60 again.
    I just want to get a few things clear.
    This will be used with a 40" TV. Is there much of a difference between the 2. The room that it will be in is not that big. What is making me look at the 260 over the 60 is that is used the Sony 2 Force Surround (or whatever it is called) It will be used with a Sony TV that has this option so if this works well then I would like that.
    The 60 it seems only used Vitrual Surround. Is there a huge difference between the 2?
    I notice that there is now also a HTCT260H which has HDMI - I personally cant see much benifit for this but if more new Sound Bars are on the way then it could be worth waiting.
    Any Tips?
