Not possible with my LG due to the TV's settings.Have you tried to compare it to the tv-speakers (when using optical) or by the tv's headphones output? If you get an echo, it is delayed.
You just told me there is no way to delay video in any television, right? So in what way do you mean it can be compensated that the XT3 delays the sound?
I was referring to an audio delay adjustment, not video. Some TV's have a +/- adjustable delay setting.
Most of the latest LG TV's mute the speakers and headphone output if Optical out is selected in the sound menu...which make's my job harder but I guess the LG designers correctly assume that if you're gonna use external equipment for the audio you don't want/need the internal speakers on at the same time.
The HT XT3 doesn't need a headphone socket, it supports Bluetooth headphones!The Canton DM50 actually was so bad at voices at low volumes, it was better to leave the tv speakers on... It was not the quelity of the sound, but rather that it had so much bass and treble boost, that the midrange level suffered. Perfectly fine on high volumes, but then you got that thunderous bass...
But since the XT3 doesn't have a headphone output, it seems like a bad choice. I mean - why mute the hadphone out when you don't need to? My Sony mutes nothing unless I ask it to, optical is always acitve. Seems logical to me.
No you can't I'm afraid.Hi, does anybody that has one of these know if it's possible to play video through one of the inputs and then music at the same time? I would like to be able to play PS4 but then listen to music as well. I guess if not I'll have to plug PS4 directly into the telly.
Thanks in advance.
It had settled down until the update - but I'm on Virgin Tivo, so Sky Q won't help :-(My sync has been perfect since Sky Q arrived.
Anyone else?
Bummer matey, but I was hoping that an update would fix the box for every source. [emoji45][emoji45]
Just tried in mine:Hi guys,
Does somebody knows how you can turn off the TV while listening to the Sony HT-XT3 ?
When I turn my TV off the soundbar turns off also and vice versa.
The soundbar is connected to my sony TV with the ARC hdmi function.
When i'm listening to music through spotify or through my own network,
it is not necessary that the TV is on the whole time.
Any ideas ?
Thanks.
Have got one of these being delivered Thursday, made sure I bought hi speed hdmi and hopefully can avoid lip sync issues others have come across , its replacing a ran not base station which sound great to me but is a bit fugly and even with base on minimum at night it still rumbles , will be plugging ps4 , now tv box and amazon fire tv into the xt3 , I'm come back Friday after I've had a day to play with new shiny object
I am taking delivery of mine tomorrow, hopefully it'll meet my expectations.
