Sony HT ST5000 remote
Discussion in 'Soundbars, Soundplates & Soundbases' started by Tony wood, Apr 26, 2018.
Tags:
  1. Tony wood
    Tony wood
    Aug 31, 2014
    5
    Hi there, hoping someone might be able to help me.
    I have recently bought the Sony HT ST5000 sound bar and for some reason when using the remote control display button, nothing displays on my TV screen. I'm really keen to know if I am outputting dolby ATMOS or at least 5.1. When watching movies via my HTPC and i press the display button it does show on my TV. However when watching a dolby movie on sky Q the display button doesn't work and the same when using my ATV4K.
    Any help would be great, I've come from a sonos sound bar with 2 x play 1's and feel a little disappointed with the overall sound, I was hoping for sound to be everywhere and over head which doesn' seem to be the case......
  2. Breezer23
    Breezer23
    Mar 24, 2018
    41
    11
    Chicago
    +4
    Which sound mode do you have it on? You'll get the widest soundstage on 3D mode.
  3. smurf_2010
    smurf_2010
    Oct 30, 2005
    450
    43
    +164
    Do you have the enhanced HDMI enabled if so it's a known issue detailed on the HT-ST5000 thread...
  4. Breezer23
    Breezer23
    Mar 24, 2018
    41
    11
    Chicago
    +4
    The display feature only works on non 4k content.
  5. Tony wood
    Tony wood
    Aug 31, 2014
    5
    Hi there, many thanks for the reply Breezer23, yes I do have it on the 3D mode.
  6. Tony wood
    Tony wood
    Aug 31, 2014
    5
    thank you will check this out
