Sjb1990
I have an LG UJ670V Connected to a Sony HT-S20R 5.1 SURROUND sound system. I just want to check I have these set up for optimum quality. I'm using HDMI ARCB and have selected auto. Also have simplink (hdmi-cec) on. I believe these are the only settings on my TV for external sound. My surround only supports 2.0 with PCM
THe problem I'm finding is occasionally the lip synch is slightly out depending if I'm using live TV, netflix or prime. TV is usually the best but adjusting the lip synch makes little difference. I think this is made worse by the sound being repeated in the surround speakers, which i find annoying.
But my main problem is having 5.1, prime works perfectly does freesat, netflix support this? If not can I stop the 2.0 sound coming out of my rear surround speakers?
