Sony HT-IS100 Home Cinema system, best connection to sky hd?
JoeKidd
Hi all. I'm thinking of getting the Sony HT-IS100 home cinema system, just have a question re connection. The sony manual says the tv & the amp should be connected by the optical cable, and connection to sky should be via HDMI. However, the sky+hd manual says the optical cable should go from the sky box to the amp. Which is best for sound? Does it matter?
:suicide:
dwhite
Sky HD only outputs stereo over HDMI. For 5.1 surround you need to connect by optical from sky to your amp.
alllaw
Not great with the lingo guys, but ive got a HDMI cable from AMP (sony htsf1300) to SKY HD box and HDMI cable from samsung tv to AMP, is this correct for 5.1 or do i need a optical cable??
allan
dwhite
stereo only over HDMI for Sky HD, you need the optical for 5.1
alllaw
Thanks for the quick reply, can you recomend a optical cable and price and ill order today, thanks allan
heathen666
I've just got a ht-is100, and have linked my sky hd box to it via optical and HDMI, but the display on the amp is saying PCM 2.0 Channel.
Are all the HD channels supposed to be in 5.1 or just the movie channels?? (which I don't get), just watched heroes on BBC HD and that was only in stereo.
I've configured the sky hd box under system settings - sound and have set the optical output to dolby d
So.. what am I doing wrong?
dwhite
Not all HD channels give you the full 5.1 sound. However I think your problem maybe that the amp is taking the audio from HDMI. Try connecting the HDMI from sky straight to the TV and just using the optical to the amp.
YellowSphere
Yup, this is the problem.
