Sony HT DDW760 / 860
Discussion in 'AV Receivers & Amplifiers' started by steveh2001, May 22, 2005.
Tags:
  1. steveh2001
    steveh2001
    Jan 5, 2005
    145
    Hope this is the right section!
    Basically i found the DDW760 for £190 - but am wondering if its better to go for the one up - the 860 and the cheapest is £260 ish i think,
    I think the only differences are an extra speaker, and 100W per channel as opposed to 80W on the 760, and i think that is has DTS-ES where the 760 doesnt
    Also can anyone recommend the 760? And i think the 20W difference in power is neglagible, so is the DTS-ES worth it? Does anyone know if there are any other differences?
    Help would be appreciated :) Just i saw the 760 whilst browsing the sony shop in camberley today, it was in the clearance section at £250, looked rather nice! Seems a good buy for a budget of £200ish
    Cheers!
  2. steveh2001
    steveh2001
    Jan 5, 2005
    145
    Thought id expand on this a bit!
    This is my 1st home cinema purchase, and i only have a bedroom to put the setup in ;) So cant get huge setups! Also im just gonna use a 24" old sony TV so the fact this amp doesnt have component isnt a huge problem,
    ANy advice and help would be very much appreciated!
