Sony Hs50 1-1 pixel mapping, sorted?
Discussion in 'Projectors, Screens & Video Processors' started by spamboy, May 16, 2005.
  1. spamboy
    spamboy
  2. UrbanT
    UrbanT
    Jan 6, 2002
    13,265
    Aldershot, Hants
    +3,031
    My understanding is that it doesn't sort 1:1 pixel mapping, it simply removes the overscan border.
    It still seems the only way to get 1:1 is by VGA :)
  3. spamboy
    spamboy
    So what happens when you send it a 1280x720 Image over hdmi?
  4. spamboy
    spamboy
    To answer my own question, from avforums
    "Simple questions with long answers. The fix changes 720P from having a black border around the edge (blanking) to filling the screen but having about 2% overscan. There has been much debate over whether or not the pre-fix units provided 1:1 pixel mapping in spite of the blanking. Some have speculated it might be better to have a pre-fix unit if this is important to you."
    I guess it'd have to be vga. I'd be pretty annoyed if I had a 720p capable player with hdmi and found that out.
  5. HSC
    HSC
    Nov 23, 2004
    1,984
    63
    Coventry
    +172
    leaving aside the debate over which is "technically" the better connection....
    which connection (to your eyes) offers the best quality picture as it stands today.?
    the analogue, but pixel to pixel VGA connection..???
    or the overscanned, but digital HDMI connection...???
  6. UrbanT
    UrbanT
    Jan 6, 2002
    13,265
    Aldershot, Hants
    +3,031
    I've tested both extensively, and can see absolutely no difference in normal viewing.
    I therefore stick to VGA as:
    a) there is no perceivable loss in picture quality
    b) reading PC text is slighty blurred on HDMI, whereas VGA is pixel mapped and therefore perfectly sharp. Reading blurred text is damn annoying as well as a strain on the eyes
    c) VGA gives me resolutions in games that HDMI doesn't
    If you have a HDMI equipped DVD player, I'm not sure why you would be bothered as none of the above apply, and therefore you should be perfectly happy. To reiterate, I didn't find he fact that HDMI isn't pixel mapped, effect the picture when compared to a pixel mapped output. :)
  7. Neelix
    Neelix
    How can I get into the service menu on the HS50? I would like to try the settings as shown on AVS.
  8. UrbanT
    UrbanT
    Jan 6, 2002
    13,265
    Aldershot, Hants
    +3,031
    On your remote, press Enter, Enter, Up, Down, Enter, then press up to select Yes.
    To come out, repeat the sequence :)
  9. Neelix
    Neelix
    Hmm, I can't get this to work :( Can you do this sequence at anytime? I assume it should bring up another menu but I get nothing.
  10. UrbanT
    UrbanT
    Jan 6, 2002
    13,265
    Aldershot, Hants
    +3,031
    I should have added, that in the normal menu's, the setup status should be turned 'on'
