sony hs3 hdmi
Discussion in 'Projectors, Screens & Video Processors' started by clancol, Oct 10, 2003.
  1. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    i see that the sony hs3 has a hdmi.
    So what would the +'s be when using a dvd player with a hdmi output?(new pioneers)
    and how much would the cables cost?
    are the cables similer to usb?
  2. warboy
    warboy
    check out the debate on DVD player forum.
    If you want a digital connection for playing DVD material I wouldn't consider anything that doesn't have HDMI (or support HDCP).
    As far as i can gather in the near future all DVD's will be carry HDCP (a copy protection standard) and to watch them via a digital connection both the source and monitor/projector will have to support HDCP.
  3. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    so what about all of us with players that dont have such connections..... that would mean we would be buggered would it not?
    ad
  4. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    what about us with the machines with the connection without sopport for hdcp.
    how do we know if it sopports hdcp?
  5. warboy
    warboy
    bit gutted, just put up my TW100, but it's still great via component.
    As always, it's the price you pay for being an early adopter
  6. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi warboy,
    It's not the DVDs which will carry the HDCP signal, it's the HDMI player that adds the signal when it recognises the Macrovision signal on a disc. This would mean, as you say, that your display would need to be HDCP compliant either DVI-HDCP or HDMI.
    Steve
  7. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    that sounds alot more reasonable!
    ad
  8. warboy
    warboy
    sorry for being a bit slow but this will determine which player I buy...
    Are you saying that if I connect a marantz DV8400 (which isn't HDCP compliant as far as I'm aware) to my TW100 with a DVI to DVI cable, I won't have problems playing DVD's that way in the future??
  9. warboy
    warboy
    sorry, ignore that last post - just found out the marantz does have HDCP. Bugger
  10. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    Portsmouth / Middle East
    +77
    I cant see why not, the dvd manufactures would not make there discs backwards compatible and if it is down to the hardware im sure there would be a software hack, "quicker than that"!
    Macrovision can be worked-around and anything else its just a matter of time.
    S.
