sony hs20
Discussion in 'Projectors, Screens & Video Processors' started by clancol, Oct 21, 2003.
  1. clancol
    clancol
    Sep 6, 2003
    988
    Middlesbrough
    +6
    what's the throw on this projecter. is it the same as the hs10.
    how much will a hdmi cable cost and how long can they be.
    same as above for dvi
  2. Noger
    Noger
    We will have to wait and see on the throw. Some way it is the same lens as the HS10, others say it is a shorter throw. NOthing officical yet.
    Have a search for DVI cables, sure there is a company that do reasonably priced ones.
  3. clancol
    clancol
    Sep 6, 2003
    988
    Middlesbrough
    +6
    when is it released
  4. Noger
    Noger
    5th officially I think. But PriceJapan have got some on the 25th October. So hopefully mine should arrive next week.
  5. ivor2003uk
    ivor2003uk
    Oct 6, 2003
    27
    london , UK
    clancol
    heres those throw distances you were looking for
    cant wait for my hs20 to arrive, on order with techtronics, delivery mid november apparently
    Standard Lens Throwing Distance:
    40" - 1.5m-1.8m
    60" - 2.3m-2.8m
    80" - 3.1m-3.7m
    100" - 3.9m-4.6m;
    120" - 4.6m-5.9m
    150" 5.8m-7.0m
    200" - 7.8m-9.3m
    300" - 12m-14m
    hope this helps you out,
    im going for a 100inch picture myself,.... big enough ??
  6. clancol
    clancol
    Sep 6, 2003
    988
    Middlesbrough
    +6
    thanks ivor
  7. Noger
    Noger
    Those are the ones from the "unofficial" pdf that has been widely circulated. They are virtually the same as the HS10. I think it is safe to say the throw won't get any longer than the HS10 ... but personally I am waiting for official confirmation before investing in a screen.
  8. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,583
    Stoke
    +55
    Are those sizes diagonal or width?
