Sony HS20 input selection
Discussion in 'Projectors, Screens & Video Processors' started by winger67, Jul 15, 2004.
  1. winger67
    winger67
    Is there any way to turn off the inputs I'm not using on the HS20 so I don't have to scroll through them each time?
    Each time I power up the HS20, it's on a different input than when I shut it off. Any way to have it power up on the same input it was powered down on?
    If there is a better forum specific to the HS20, please point me there.
    Larry
  2. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    749
    16
    Derbyshire
    Hi Larry,
    To get the HS20 to remember your last input setting and not adjust each time the projector is turned on you have to go to the SET SETTINGS menu and then turn the AUTO INPUT SEARCH: OFF.
    This should stop your problem, I did have this myself and its annoying to say the least!
    With regards to turning off or disabling inputs, its impossible as far as I know.
  3. winger67
    winger67
    Thanks! That helps alot. I would have thought Auto Input Search would have found the input that has signal but doesn't seem to work that way.
    I have an HD DirecTivo hooked up to the HDMI but don't seem to be getting sound from the HS20. Should I be? My guess is that there is no digital to analog decoder in the projector.
  4. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    749
    16
    Derbyshire
    Lo again,
    I haven't a clue as far as sound output from the HS20. Its something I've never used nor intend to.
    Can I ask why would you want the HS20 to output sound, do you use yours for presentations etc?
  5. winger67
    winger67
    If I'm just watching the news or other times I don't care about audio quality, I thought it'd be convenient to use the speaker in the HS20 instead of having to switch on the receiver. No big deal, though.
