Sony HS20 Discretes
Discussion in 'Home Cinema Control & Remote Controls' started by jlcd, Jul 2, 2004.
  1. jlcd
    jlcd
    Nov 14, 2003
    23
    Can anyone tell me where I can get discrete codes for the HDMI and DVI inputs for my Sony HS20 Projector. I can't get them from RemoteCentral, or from any Sony HS10 Projector files. I know I can use a macro that starts at a known Input discrete code then jumps forward using the Input command, but I'd rather have the actual discretes (if they exist). Can anyone help?
  2. ailean
    ailean
    Not found any myself yet but still looking. You may want to investigate the big Sony lcd remotes and see if you can find details on the database entries on those for the HS20, I'd imagine if it's not in there then they don't exist. ;)
