Sony HS20 Connections
Discussion in 'Projectors, Screens & Video Processors' started by Rob D, Aug 30, 2004.
  1. Rob D
    Rob D
    Aug 20, 2003
    Just about to purchase a Sony HS20 for our offshore platform and I was wondering what we get in the pack and what cables would we require.
    We will be using it for DVD's (component), TV signal probably from a video and a PC.
    I understand you get a 10m cable supplied which you can plug in various devices correct?
    I presume I need a DVI-D to VGA cable to allow me to connect a PC to the PJ as our PC only has a VGA output.
  2. rattlesnake
    rattlesnake
    Not sure what cables come with the HS20 - maybe Kramer can help.
    I got various cables with my Panasonic including vga-vga, s-video and component. There may even have been a composite cable.
    Anyway none of that will help just wondering what platform you are on.
    Andy
  3. Rob D
    Rob D
    Aug 20, 2003
    Andy,
    I'm on the Brent Alpha and Eider, you work offshore as well?
    Regards, Rob.
  4. Goragio
    Goragio
    IIRC the PJ Multi cable has composite, svideo, component on the end.
    So that'll do for the dvd but you'll need an extra cable for the computer.
  5. rattlesnake
    rattlesnake
    KCADEUTAG engineering....
    Currently working on a BP BAKU project.
    Been on the Alpha but not the Eider.
    Sorry if this is a bit off topic - small world eh!
    I would be surprised if they give you a 10m cable with the PJ.
    You get a VGA to DVI converter.
    See link for example
    http://www.ramelectronics.net/html/DVI_monitor_cables.html#adapters
    Some of the guy's with sony's should step in soon an let you know what comes with the PJ.
    Andy
  6. Rob D
    Rob D
    Aug 20, 2003
    Rattlesnake, tis a small world!! :)
    Goragio, sounds about right to me looks like all I need is a DVI-D to VGA cable or adapters, anyone else can confirm this?
  7. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,583
    Stoke
    +55
    The HS20 does indeed come with a 10m pj multi cable, allowing component, s video and composite inputs. There is also dvi and hdmi inputs for your computer to connect to, you just need the right adapter.
    Hope tat helps
  8. Rob D
    Rob D
    Aug 20, 2003
    Cheers Mike! :)
