docfeelgood
couple of quicks ones for you...
I'm want to connect my Dreamcast to the HS20.
I've bought a 10m VGA cable.
I also have a VGA-DVI adapter which worked fine with my Z2 but does not fit the HS20 (four too many extra pins around the flat pin). I believe I need a VGA - DVI-D adapter (I think). Is this correct and where can I buy one?
Also... I need a decent quality 10m component lead. I've seen that Nexnix do one for £30 ish and so do Keene. Anyone got any opinions on these or can suggest another on personal experience?
best regards
Doc
best regards
Doc
