Sony HS10 setup help
Discussion in 'Projectors, Screens & Video Processors' started by jtorry, Jun 28, 2004.
  1. jtorry
    jtorry
    Nov 8, 2001
    523
    I got a HS10 delivered today and am using a Momitsu 880 DVD player with DVI output. I set the HS10 to digital input and the dvd player to any of the DVI output modes but I cant get the sony to go wide or to display the whole image. I am missing something? Do I need to set a custom res on the momitsu?
    edit: the projector is only displaying a 4:3 image and it just seems to enlarge the image when increasing the input res. eg 480p text on screen is small but in 720p the text is much larger so not as much is on screen
    edit 2: I just tried composite video and it displays correctly in full widescreen. Must be a setting somewhere I am missing.
