Sony Hs10 Powerstrip Settings
Discussion in 'Projectors, Screens & Video Processors' started by RASH PATEL, Sep 19, 2003.
  1. RASH PATEL
    RASH PATEL
    Feb 3, 2001
    110
    16
    Hi all,
    My new HTPC consists of Radeon graphics card linked
    DVI to my H10 PJ.I have configured Powerstrip using
    parameters suggested in this forum
    1368x768=1368,88,144,232,768,1,3,30,82280,7
    and the PJ seems to work OK. However, when I display settings on the PJ (Information menu in HS10), the PJ shows:
    FH _45.01 _
    FV _56.04
    Prog. NO: 121
    1366x768 _
    According to Sony Manual programe No if correct 1:1
    mapping ,should show _51,however the PJ shows _
    121 !!
    Am I doing something wrong?
    Any help would be most welcome,
    Regards,
    Rash
  2. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    Hi Rash,
    I am using slightly different PowerStrip settings to you and mine shows up as mode 51.
    Here are my PowerStrip settings:
    • 1366x768=1366,65,142,207,768,1,3,21,79046,39
    • Horiz res: 1366
    • Vert res: 768
    • Horiz refresh: 45 Khz
    • Vert refresh: 56 Hz
    • H-sync: negative
    • V-sync: negative
    Hope that helps,
    Cheers, Lee
  3. RASH PATEL
    RASH PATEL
    Feb 3, 2001
    110
    16
    Hi Lee,
    Thanks very much for the info. Will try your settings,
    Kind regards,
    Rash
