Sony HS10 connection help please.
Discussion in 'Projectors, Screens & Video Processors' started by Talisman, Jan 23, 2003.
  1. Talisman
    Talisman
    Jan 10, 2003
    53
    England
    After reading this forum for the last few months, and changing my mind a lot, I purchased the limit progresive scan 9000se DVD player and the Sony HS10 projector. My query is whats the best way to connect it all up with my current equipment, ie a telewest cable tv box and my denon av 2802 receiver?
    your help will be very gratefully received
    thankyou
    Talisman
  2. Kramer
    Kramer
    Firstly, hi & welcome to the forums ;)
    Best connections in decending order (HS10 wise) are:
    DVI (via Radeon based HTPC)
    Progressive component
    Interlaced component (i.e. standard)
    S-video
    Composite.
    Don't know what connections your Limit has, but most likely prog. component.
  3. Talisman
    Talisman
    Jan 10, 2003
    53
    England
    Thankyou Kramer, Im pleased to be here. :)
    I am hoping to use Progressive component from limit to denon avreceiver to HS10 and somthing similar from Telewest cable TV box (scart to denon avreceiver?) somehow. what I'm wondering is what cables do I require to do this or do I need converters?
    thankyou
