Sony HS1 broken screen
Discussion in 'Projectors, Screens & Video Processors' started by gavan, Aug 4, 2002.
  1. gavan
    gavan
    Dec 20, 2001
    3,984
    Rapture
    +287
    Anyone else had problems with the supplied screen breaking? The other day the plastic bit which prevents you from extending the supporting pole too much broke off and a a result I actually lifted it too far when raising the screen and had it shear off.
    Also, the plastic cap at the bottom end of the pole cracked .. probably as a result of the forces when the pole sheared.
    Anyhow, you can still use the screen (just about) but it's a lot more fiddly (if you watch when raising the pole you just stop when the bottom reaches the point where it's supposed to stop).
    Hopefully the judicious application of some superglue will fix the cap and maybe the stopper.
    Gav
