sony hi 8 in dig vid cam
RON
Joined
Sep 20, 2002
Messages
73
Reaction score
Points
30
Location
uk
does any one know if my recordings from a sony hi 8 camcorder will play in a digital camcorder so i could use the fire weire to get the film onto pc
thanks
Yes! Some, but only some of the Sony Digital8 camcorders can play the analogue 8mm/Hi8 tapes. You will then be able to capture the footage on your PC via firewire.
I would suggest you take an old tape to your local Jessops and try it. If you find a cam you like then find the best web price and as long as you have the sites details they will match the web price for you.
Mark.
Just had a quick look on the Sony site and found this:
DCRTRV460E
Features:
Digital 8 recording
USB connectivity
SteadyShot
High stamina battery life up to 12 hours
20x optical zoom
990x digital zoom
Click to DVD
i.LINK (DV IN/OUT)
12bit / 16 bit PCM stereo sound
Remote control
Touch panel control
Memory Stick slot
MPEG MOVIE EX
Analogue input
8mm playback ability
Mark.
now to find a friend with one thats willing to lend it to me.
I had temporary use of the Sony TRV33 . I managed to record stuff from my Sony Hi8 camera via it's analogue inputs incl SVHS onto mini tapes. Then firewired it across onto my PC and finally onto a DVD.
As long as the new digital camera has analogue inputs and specifically SVHS connection then it should be fine.
Sony BRAVIA 9 Mini LED TV: The Best HDR TV EVER?
Back
