Sony headphones MDRNC6 compatible with Walkman NW-S703FB ?
Discussion in 'Headphones, Earphones & Portable Music' started by bourne37, Apr 27, 2007.
  1. bourne37
    bourne37
    New to the MP3, this has earphones.
    I have an old set of headphones from an old tape Walkman that work ok but not perfect.
    I would like a larger headphone and assumed that the Sony MDRNC6 should plug in and maybe give some benefit from the noise cancelling.
    I would appreciate any comments.
  2. Busy Builder
    Busy Builder
    Sep 15, 2006
    45
    You'll find that the noise cancelling is also partly down to the speakers in (the outer part of) the ear phones themselves.
    So, using a different pair, the noise cancelling wont work.
  3. bourne37
    bourne37
    Busy Builder
    Thanks for your reply.
    Is the noise cancelling built into the MDRNC6 headphones ineffective because of the noise cancelling built into MP3 player ?
    I had hoped the headphones would replace the noise cancelling of the MP3 + earphones.
