Sony head unit into Audi?
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by pgreen, Mar 16, 2005.
  1. pgreen
    pgreen
    Hi -
    I am struggling to fit a Sony head unit into my Audi.
    The car is an Audi A4 with its standard wiring loom - that means that its head unit wiring terminates in 3 block connectors.
    My Sony head unit has a Sony-specific plug on the back.
    I bought a lead convertor which plugs into the Sony unit fine, but which terminates in 2 female blocks... not the three that I require.
    Do I need to re-wire the car end of the plugs, or send the converter back?
    Cheers!
    Paul G
  2. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,286
    +7,407
    The Sony should have been supplied with a Sony-ISO cable unless you got it second hand. You now need another adapter to convert the Audi wiring to ISO also. I guess you need one of these but no idea which. Give then a call.
