Sony HDX860 - can't set EPG timer
Discussion in 'Blu-ray & DVD Players & Recorders' started by elcart, Jun 12, 2008.
  1. elcart
    elcart
    If I try to record a programme using the EPG timer it sets for about 2 secs then cancels.
    I can set timer manually OK.
    I've tried running with auto updates on and also off.
    I've powered off and on.
    The annoying thing is it works very very occasionally, about once a month.
    Is there any trick to get the m/c working properly?
    Dealers I've spoke to are no help. Typically they suggest the signal is not good enough but it is at full strength and quality according to the technical info screen.
    I've struggled with this for over a year now and feel like ditching it.
