Sony HDT500 Hard Disk Drive
Chosun
My Sony HDT500 hard disk has just died :(
It's out of warranty, so I'm going to crack the case open and replace the drive with a new one.
I just wondered if anyone had tried this before, and if so what type of drive I should get? I have yet to get the screwdriver out, but I think it may be a standard 2.5" SATA drive.
Any information would be very helpful.
Thanks!!
petrev
Thanks!!
Western Digital 3.5" AV-GP hard drive.
WD AV-GP
Chosun
Thanks to both for the answers.
Forgive my ignorance, but does the AV-GP drive have better speed, larger cache, or some other feature over and above a "standard" WD drive?
petrev
Multiple continuous stream support and no error checking. They are specifically designed for PVR use - lower energy consumption and heat production.
Chosun
Great, thanks.
I'll get the box opened up tonight and get my order in for an AV-GP drive as well.
jazz_qwerty
thanks for quick reply, I managed to get it working under windows 7, i can see the drive, save to it etc..
but still not joy with the sony, its a hdt500, and the drive I purchased is wd10eurx wd av-gp 1tb
petrev
Win7
Attach HDD with computer Power-OFF (Spare SATA)
Load Win7
Desktop > Computer~RightClick :Manage
Storage > Disk Management
Should detect uninitialized HDD - Choose Initialise:MBR
Don't need to partition or Format but should be OK if you do.
Power OFF PC - Remove HDD.
Attach HDD to SONY (Power-Disconnected)
Boot : MENU > Others > Disk > Format Disk : PIN:0000 > YES > YES
Reboot > OK
:thumbsup:
Pete
jazz_qwerty
I’ve tried all that, with this drive and unfortunately this doesn’t seem to work, the Sony doesn’t seem to see it - don’t get the option to insert pin ether,
I’ve tried another western digital blue drive and that worked, just not the western green av drive :(
grahamlthompson
im just as puzzled, i guess this drive simply isnt compatible with the HDT500/1000
Is the problem drive a sata 3 model by any chance ?
grahamlthompson
Gooogle suggests it might well be . . .
The Foxsat-hdr also apparently has the same problem with sata 3 drives. Could be worth contacting WD to see if the drive has a firmware downgrade to sata 2.
grahamlthompson
sila1999
Using a windows PC to initilise the drive has nothing to do with it, what you must do is the following
STEP2 (Diagnosis and Format the HDD) The recorded contents on the HDD will be erased.
1. Connect a USB memory to the USB jack on the unit.
2. Enter the service mode.
Press six buttons in order of the [System Menu] [PIP] [4] [5] [6] [7] on the remote commander.
3. Select [5 Performance Check].
4. [HDD Check] will start. (The check takes 2-3 hours)
5. The diagnosis data will be saved in the USB memory as text file.
6. Open the text file with "WordPad". The diagnosis data will be displayed.[Fig.-1]
7. Confirm the "Self-test execution status" number shown in parentheses.
8. Judgment and Remedy
( 0): [No problem] Format the HDD.
Press/select four items in order of the [System Menu] [Others] [Disk] [Format Disk].
(Others): [ NG ] Replace the HDD with a new one.
9. After formatting the HDD, the unit will restart.
10. Finish.
petrev
10. Finish.
This is great info - Thanks. :thumbsup:
But . . . The OP is trying to get a replacement HDD to be recognized.
A drive has to be initialized in order for it to be seen by the SONY box.
Once initialized then it has to be partitioned and formatted by the SONY to XFS.
The only other method I can think of that could be tried, is to install into a USB enclosure (one that is known/tested to work with this drive) and then attach to the SONY USB port and Format from the Menu as a USB external drive.
Then swap from the enclosure into the main box and see if it works ??? I have only tried it the other way - Original Internal HDD moved to USB enclosure.
Pete
sila1999
My mistake, the drive should be recognised straight out of the package. there is no need to do anything else, if his box does dot recognise the new virgin HDD then the MB may be faulty as well. This is what the service site say about this model
Trending threads
Latest News
AVForums Podcast: 9th August 2020
  • By Phil Hinton
  • Published
Linn announces Majik DSM digital streamer upgrade
  • By Andy Bassett
  • Published
Sony announces WH-1000XM4 noise cancelling headphones
  • By Andy Bassett
  • Published
McIntosh launches C22 Mk V preamp and MC1502 power amplifier
  • By Andy Bassett
  • Published
Marantz unveils 12 Series Special Edition models
  • By Andy Bassett
  • Published
