Sony HDR-HC1E and Apple Imac G5
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by DJ Dave, Aug 6, 2006.
  1. DJ Dave
    DJ Dave
    Oct 21, 2004
    1,186
    Danbury, Essex
    +50
    I need some help please.
    What method should I use to upload video footage from my HC1E to an Apple Imac G5?
    According to the manual I need to do it via "I Link"?
    I don't think the G5 has an I Link socket? Only USB and Firewire. Sorry if this is a bit basic but I've never transferred video footage before so am not sure what I'm doing !
    Any help would be gratefully received! :thumbsup:
  2. noidea
    noidea
    Jun 8, 2004
    985
    46
    +123
    ilink is sony's name for firewire, so you'll be fine
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,547
    Rainham Essex
    +2,523
    Yep, same conection just different names - and theres more of them :rolleyes:
    iLink = firewire = DV port = ieee1394 = MV port (only on microMV cams) = ????? (yep there are probably others that I have forgotten).
    I'm not sure about on a Mac, but most desktop PC's have a six pin firewire connection and the cam will have a 4 pin firewire connection. Therefore you probably just need to get a 6 pin to 4 pin (or possibly 4 to 4, check the port first) firewire cable for under £10 (no advantage with expensive branded cables). It is also adviseable to get a cable no longer than 1.8m as longer cables are often problematic.
    Mark.
  4. DJ Dave
    DJ Dave
    Oct 21, 2004
    1,186
    Danbury, Essex
    +50
    Thanks guys. :smashin:
