Sony HD5 stoped working
Discussion in 'Headphones, Earphones & Portable Music' started by cela, Jul 27, 2005.
  1. cela
    cela
    Im curious if anyone else has had this problem and how you solved it.
    Suddenly my Sony HD5 just stoped. I can't turn it off, it's frozen. The screen is on and the backlight is on. I've tried to turn it off, it doesn't respond.
    Ive tried to "bring it to life" for hours now, nothing happens.
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,436
    +6,224
    pull out batt then re insert?
  3. cela
    cela
    How do I remove the battery?
  4. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    Put a pin or a thin object in the little hole beside the "^BATT" compartment and lift.
  5. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,551
    England, UK.
    +554
    And after that update the firmware to 1.2 (if you have not done that already) as it is supposed to address the problem.
