N
NeoGeo
I recently bought an HD5 and I'm very pleased with it but I have a question about the screen and backlight.
- When the backlight is turned off the screen looks a bit 'dirty', certain areas are not completely blank. They are slightly black, you still can read everything but it's not 'stylish'.
- When the blacklight is turned on the same problem occurs. When you browse trough the artists/songs/... the highlighted text is not completely black (it more looks like brown/red on my screen btw) but you can see stripes and dots which are lighter.
I used the 'positive' setting.
- When I look at the screen from the side it flickers a bit, with the backlight switched one it's more noticeable.
Is this normal or am I the only one with this problem? I'm a bit worried as my unit was exposed to the sun where I bought it. It was the last black unit the shop had so they had to take it from the display...
