Sony hd5 question. An easy one for anyone who owns it....
Discussion in 'Headphones, Earphones & Portable Music' started by mike5622, Aug 22, 2005.
  1. mike5622
    mike5622
    Feb 13, 2005
    10
    ok, mine just got delivered today. now...
    the sliding flap thing on the top. should it have two bits of plastic attaching it to the main unit? mine only has one and it seems very flimsy. should there be one at either side?
    thanks.
  2. KiNeL
    KiNeL
    Aug 18, 2005
    333
    Essex
    +7
    No there is only one and I agree, it does not inspire confidence in longevity !
  3. mike5622
    mike5622
    Feb 13, 2005
    10
    strange. it certainly looks like they've designed it for two! lets just hope the one they have put in is strong enought to keep the cover attached and it's not an issue in a few months time.
  4. ak47wong
    ak47wong
    Aug 5, 2005
    115
    Sydney, Australia
    It's supposedly not an issue, so I understand. Be careful when you unplug things from the HD5 too. Once when I was trying to disconnect the USB cable, I inadvertently grasped not only the plug but the sliding flap as well and gave both a damn good tug when they wouldn't come out. Took me a few seconds to realise what I was doing, so the flap got quite a stretching there, but it seems to have survived :)
    Andrew
  5. DantheMan
    DantheMan
    The thing is, on most daps you only get a thin bit of rubber or plastic covering the usb port. I always lost mine for my iPod/H10 anyway. I know its flimsy, and a slide off aluminium cover would have been nicer but to be honest if it comes off I don't care :D. Would expect more for £180 though.
  6. KiNeL
    KiNeL
    Aug 18, 2005
    333
    Essex
    +7
    To be honest I'll be more surprised if mine DOESN'T fall off at some time but it won't be the end of the my world and not sure I'd make too much fuss about it. I've got a Sony shop in my town and I'd probably go there and stamp my feet but leave it at that. I need my music much too much to be without it whilst sending it away.
    I echo your comment though and I would perhaps have expected more from Sony but we have to remember that they're selling in a highly competetive market which, like it or not is dominated by the iPod, and there's only so much price premium they can attach to the Sony name.
    Incidentally, I was disappointed with the USB lead supplied, it's so stiff and horrible. Why when there are plenty of nicer more flexible ones around ?
    Fortunately I've got one so their's has stayed in the box.
    And as for those bloody great RF chokes on the charger..................now I'm ranting....lol
  7. ak47wong
    ak47wong
    Aug 5, 2005
    115
    Sydney, Australia
    And it's so short!
    Andrew
  8. shirleywhite
    shirleywhite
    Mar 28, 2005
    177
    +10
    A quick word in defence of Sony (for once?!) Like most I originally thought "flimsy/broken?" re the usb cover. But realised it was designed that way. It's actually a lot tougher than it looks. And thinking about it - a very flexible cover would take knocks/pulls etc ( compare say a hard metal thing with hinges - a hard knock and it's broken off or bent?!). Final thought - sony put very similar cover on digital cameras - my DSC-P7 cover has worked fine for approx 3/4 years now!!
    PS Got a black HD5 - no button cracks still - about 4 months now!!
  9. mike5622
    mike5622
    Feb 13, 2005
    10
    well i'm inspired with a bit more confidence about it now. thanks :thumbsup:
  10. IanPM
    IanPM
    Jan 12, 2004
    389
    +6
    I've tugged mine (oh err) and it seems like its very well secured. I don't think this will come off at all.
